Noise from left door area - SOLVED
English-speaking 207 fans are welcome in our forums !
Messagepar Plex » 13 Septembre 2006, 21:27
Hello
Has anyone observed, some rattle noise from left door area? It comes when driving over 90 km/t. It's really annoying :cry:
The car has only driven 500 km
Hope someone have a solution.
Greetings from Denmark
Modifié en dernier par Plex le 14 Septembre 2006, 21:43, modifié 1 fois.
Otto
207 HDi 1,6 110 S16 3d
Plex
Messagepar Plex » 13 Septembre 2006, 22:00
I think this problem is the same, but I can't understand what the solution is.
Can some please explain it to me?
Thank you
Otto
Plex
Messagepar west_indies » 14 Septembre 2006, 01:20
C'était juste une agrafe manquante sur l'avant de la baguette latérale, forcément la vitesse décollait celle-ci et la faisait taper. Plus aucun bruit, même à 130.
Super :D
It was a missing staple on the front of the side stick, the speed unsticked it and beat on it. Now Any noise even at 130 km/h
Super :D
Messagepar Plex » 14 Septembre 2006, 06:42
west_indies a écrit:C'était juste une agrafe manquante sur l'avant de la baguette latérale, forcément la vitesse décollait celle-ci et la faisait taper. Plus aucun bruit, même à 130.
Super :D
Super :D
Thank you, but what is a stable? I really do not understand :cry:
Otto
Plex
Messagepar HarikenRed » 14 Septembre 2006, 07:43
It's a retaining clip, which clamps the stick on the door!
HarikenRed
Messagepar Plex » 14 Septembre 2006, 15:35
HarikenRed a écrit:It's a retaining clip, which clamps the stick on the door!
Okay now I nearly understand :D
Can you come a bit closer? Where can I locate this clip - inside the door?
Is this a common problem on the 207?
Thanks alot for your help :merci:
Otto
Plex
Messagepar Plex » 14 Septembre 2006, 21:42
Problem is located :)
The bumplist on the left door, is missing one or two clips! The list is making resonans chamber.
Hrmmm shame on you - Peugeot! :fouet:
Otto
Plex
Messagepar minas » 15 Septembre 2006, 11:50
the truth is that at some points Peugeot seems to have lowered the quality of the plastics, or the care that they should show when they put the plastics together.
my 207 is from a French factory. I dont have weird noises at all.
I have the feeling that the need to deliver the cars makes the factories work a little bit careless.
nevertheless, 207 is a FANTASTIC car. :D
Minas
Minas N. Miliaras
Athens, Greece
minas
Retourner vers The English 207 board !
