I'm from Italy.
Can someone translate the entire thread in english?
http://www.feline207.net/forum/viewtopi ... 30&start=0
I have this problem. I want to buy the "pédalier alu" for my 207 but the dealer said that there are some problems with the gas pedal.
He sayd something about changing the entire gas lever because in the gas pedal there is an electric contact (variable resistance).
I don't know french but I can suppose that the solution for my problem is written in the first post of this thread but I cannot understand it well:
"Nota : pour la pédale d'accélérateur vous devrez percez peut être les trous. Cependant, pour vous aidez, il possible de déposer sans trop de difficultés la pédale avec une simple clé à pipe n°10 (pour écrous M6) en pensant à débrancher la fiche du contacteur. Le remontage tout aussi simple et sans danger."
Is there a manual with the alu pedals? What does it say?
Thanks a lot to all!
Edit Admin : Post moved to the English section of the forum
