cruise control aftermarket
English-speaking 207 fans are welcome in our forums !
Messagepar tux » 06 Octobre 2006, 11:33
HI all,
is somebody familliar with this? In an other topic M@X said:
So, here I'm! And with my 207 with a brand new cruise control! Yes, it took only 15 minutes, just to unscrew the steering cover, plug the cruise control commands, screw the cover and activate it with the Diag 2000! And it works perfectly as the optional one. Total price? 43€! Unbeliavable, 157€ less than the oprtional one!
So, see you and if someone have question about the cruise control post here a mesage.
Bye bye. M@X
Does somebody know part numbers? And maybe an howto for this, with pictures or something?
tux
Messagepar pilou » 06 Octobre 2006, 13:39
On this forum, we never hear about this modification.
Is it realised by the Peugeot Garage itself ?
pilou
Messagepar tux » 06 Octobre 2006, 16:34
pilou a écrit:On this forum, we never hear about this modification.
I dont know, i'd like to know, and perhaps a lot of other members too, cause its a nice extra for your car for relative a small amount of money!
tux
Messagepar Rokp » 11 Octobre 2006, 01:02
It means that the cruise control is mount in all 207, whatever are the versions/options.
That's possible but I've never heard about that.
'Can't make the scene if you don't have the green !'
207 HDI90 SP - Noir Obsidien - 2006
Rokp
Messagepar tux » 11 Octobre 2006, 07:57
Rokp a écrit:It means that the cruise control is mount in all 207, whatever are the versions/options.
Yeah probably, so i'd like to know that :)
tux
Messagepar pilou » 11 Octobre 2006, 09:59
You're right, we all want to know that.
Is it possible for you to ask it to your dealer ?
pilou
Messagepar axl » 12 Octobre 2006, 21:25
i have tried it last week aswell with a regular CC control and the CC/limiter control.
but it didnt work, only thing what did work is that the sign in the display lit up ;)
possible reason could be, that the PPS didnt allow me to enter the motormanagement. and for the VAN 307 it was needed to switch it on aswell in their..
when i got the chance i ll try again with a other car, but only the single option CC control might work since you need a different gaspedal to get the limiter function to work
axl
axl
Messagepar tux » 16 Octobre 2006, 17:40
thats bad, im wondering how the italian guy fixed this then?
tux
Messagepar le.gris.félin » 23 Octobre 2010, 22:12
anything new about this topic ?
le.gris.félin
Messagepar macs1971 » 26 Juillet 2012, 17:00
Hi,
if somebody cares, I`ve done this modification resently on my car.
It's quite easy. Just plug n play. Arccording the Crusie Control, you've got to plug in the Command.
After that is has to be teached into two "computers" of the car.
That has to be done with the Peugeot Planet Software.
The cruise control itself is working properly, but the Speed Limiter requires a switch under the trottle pedal.
Drive faster to arrive earlier!
macs1971
Messagepar viper » 26 Juillet 2012, 19:53
It is not a switch under the pedal, but a special pedal with inside a different resistance witch send the correct message to the motor controleur.
Messagepar Guest6762538 » 06 Août 2012, 22:24
You speak very well english viper. :lover:
Retourner vers The English 207 board !
