http://www.12tune.com/en/manufacturers/d2-racing-sports/d2-racing-sports-big-brake-kit-front-286x26-6-pot-for-peugeot-207-rally-gt-rc-2008-up.html
Dites moi si vous connaissez ce modèle et c'est performance.
Prix : 1339€
- 6 Piston Front Brake Kit has 304 mm diameter, 28mm thick brake discs and is suitable for 15" wheels or above.
- We recommend you to choose the same rotor size for front and rear when you purchase D2 Racing Sports brake kits. The reason is our pad ratio for front and rear is 7:3. If you choose the same size of front and rear rotor, the brake balance will be the best. You no need to choose the front rotor size larger than the rear which likes the original, if does that is no good for your vehicle.
- Custom Color Option Available. Please choose "Custom Color" and we will contact you about the custom color.
S'il y a un spécialiste en anglais merci d'avance pour la traduction.
207 THP Stage 3 280 Cv 400 Nm
toi du va direct dans la bac à gravier
moi je vais nul part suis à pied
