Hello, I have just taken delivery of my new 207 1.6 Sport, does anyone know how easy it is to remove the black grill and replace it with the silver version. Do you have to remove the bumper as in the 206?
Many thanks
Geoff
Front Grill
16 messages
You'd better find a technical book such as Haynes.
http://www.haynes.co.uk/webapp/wcs/stor ... ogId=10001
I don't know if such a book exist for the 207 but this is probably the next thing that I will search for.
'Can't make the scene if you don't have the green !'
207 HDI90 SP - Noir Obsidien - 2006
Rokp - Petit Félin
Front Grill
Well, I managed to remove the front bumper and replace the old black grill with the new GT silver grill.
<a href="http://img230.imageshack.us/my.php?image=207sporttp2.jpg" target="_blank"><img src="http://img230.imageshack.us/img230/2336/207sporttp2.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
207 1.6 110hp Sport Flamenco Red
geoffm - Nouveau
Front Grill
geoffm - Nouveau
Thats very cool. Professional job (looks like you bought a GT).
So...i guess the question is:
How easy was it? And where on earth did you get a silver grille from? How much did it cost? How long did it take?
Thats more than one question isnt it. Sorry.
Im really interested in this mod. Please let me know.
Cheers,
Matt
Cheers,
Matt
- MATTnJUDELLE
Front Grill
Hi Matt,
The Grill comes in 2 parts, upper and lower, the 2 parts cost £130.00, I have the part numbers if you require them.
Fitting is not to bad, the bumper is held on by 4 screws visible when you raise the bonnet, then you have to release the front of the wheel arch liner on both sides of the car, held by plastic clips (4). Inside the wing the bumper is secured by 2 bolts on each side, remove these and the 2 bolts under the number plate, unclip the cables to the fogs, and carefully lift the front clear. It sounds complicated but it is pretty easy. The lower grill clips in, but the upper is glued/welded in a few places, cut the welds with a sharp knife and it come out after removing the 2 securing screws, it is a bit of a fiddly job. I used a hot glue gun to weld the new grill in place. From start to finish less than 1 hour. Oh and make sure you place the bumper on a blanket to protect from scratches.
Modifié en dernier par geoffm le 29 Octobre 2006, 22:11, modifié 1 fois.
geoffm - Nouveau
Front Grill
Oh and the next job is to have the side rubbing strips painted
about £60 I have been told.
geoffm - Nouveau
Front Grill
Upper Grill P00007414QE
Lower Grill P00007414QG
These are the UK part numbers, though they should be universal.
Good Luck
Good Luck
geoffm - Nouveau
Re: Front Grill
geoffm a écrit:Upper Grill P00007414QE
Good Luck
Thank you so much
Otto
207 HDi 1,6 110 S16 3d
- Plex
Front Grill
Thanks Calimero, we dont have the sport pack option in the UK, but we do get Alloy wheels on the sport as standard.
geoffm - Nouveau
Re: Front Grill
geoffm a écrit:Hi Matt,
Hello
Geoffm!
I've also bought the new front grill
How did you get the the bolts off, in front of the wheel arch? God damm they are sitting the wrong place
Did you take off the plastic fender?
Thank you
Otto
- Plex
Front Grill
Sorry for the delay in responding,
You have to release the wheel arch liner first, its held in by plastic clips, once you have released the liner its easy to get at the 2 bolts on either side.
Removing the front wheels makes the job of releasing the liners a lot easier. Good luck
Geoff
Geoff
geoffm - Nouveau
16 messages
Retourner vers The English 207 board !
