Speaker wiring for trebles
English-speaking 207 fans are welcome in our forums !
Messagepar kfuglsang » 17 Juin 2007, 17:36
Hi all,
I'm starting to replace the speakers in my 207, but have stumbled upon a minor, but annoying problem.
I've disassembled the dashmounted trebles in each side of the car, but am wondering how I'm supposed to run new speaker wires to the trebles (preferably from the doors).
How do you guys wire your aftermarket speakers?
Best regards
Kenneth
Denmark
kfuglsang
Messagepar Sanja » 17 Juin 2007, 20:44
you say about "+" and "-" wires?
By the way tell a few process of remove facia of doors?
Well with photos :)
it is interesting as what they - stock speakers...
309 GR 5d-> 405 GL BK -> 206 SW -> 307 SW
madman :)
Sanja
Messagepar kfuglsang » 17 Juin 2007, 21:14
Yes, I want to know how I should get the new cables to the trebles in the dashboard.
I'll try to remember to get picturess, but it won't be for a few weeks probably as I'm about to graduate from highschool (monday the 25th).
kfuglsang
Messagepar Sanja » 17 Juin 2007, 21:47
it's easy :)
How to check up polarity of wires from the head device:
-turn ON music
-connect tester (multimeter) in DC-mode to end of wires and look result.
-if indications is positive, you see + and-
-if indications negative that polarity is incorrect
How to check up polarity on speakers:
-connetct any little battery on wires to outputs of columns
-look at behaviour of a magnet in speakers
-if it will move upwards that polarity is similar to plugs of the battery
-if downwards that is not present
Success in the end of highschool ! :)
madman :)
Sanja
Messagepar kfuglsang » 17 Juin 2007, 21:50
That wasn't quite what I meant:)
I'm going to install an amplifier and new speakers in my car. For this install, I wan't to use new wires instead of the original that are in the car.
My question is how I will get the cables from the door to the trebles, that are mounted in the dash (I can't find any holes etc.)
kfuglsang
Retourner vers The English 207 board !
