Informations générales
GENRE DE PRODUIT VEHICULE PARTICULIER
MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
LIGNE DE PRODUIT 207
SILHOUETTE COUPE CABRIOLET 2 PTES
FINITION COUPE CABRIOLET SPORT 2
MOTEUR INJECTION EP6
TRANSMISSION BVM5
TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
COULEUR DE CAISSE EZR - PEINTURE GRIS ALUMINIUM
TYPE D’HABILLAGE INTÉRIEUR MAILLE PAYERNE + OMNI "SJ"
COULEUR DE GARNISSAGE "FZ"
BOITE DE VITESSES (CARACTÉRISTIQUES) BVM MA5 / S
MOTEUR (TYPE) MOTEUR TYPE EP
"sport 2"; si quelqu'un sait ce que que ça veut dire...
Equipement intérieur
ALARME ANTIVOL SANS ALARME ANTIVOL
APPUI-TÊTE ARRIÈRE SANS APPUI TETE AR
APPUI-TÊTE AVANT APPUI-TETE AV ARTICULE
ASSISE ARRIÈRE BANQ AR COUS MONOBLOC DOS SEPARES NON RABATTABLES
CACHE-BAGAGES SANS CACHE BAGAGES
CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 2 ENROULEURS 3 PTS + TEMOIN BOUCLAGE
CEINTURE DE SÉCURITÉ AVANT ALARME BOUCLAGE CONDUCTEUR + PASSAGER
CLIMAT (TEMPÉRATURE AMBIANTE) PAYS TEMPERES
CONDAMNATION ENFANT SANS CONDAMNATION ENFANT
GRADUATION VITESSES GRADUATION EN KM/H
COMMODITÉS (POIGNÉES) SANS POIGNEES
CONDITIONNEMENT RADIO ALIMENT ANTENNE RECEPTEUR HP AV/AR TWEETER
COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
COMMANDE À DISTANCE MONTAGE CDE A DISTANCE
ECLAIRAGE RANGEMENT ECLAIRAGE BOITE A GANTS
EQUIPEMENT PLANCHE DE BORD PLANCHE DE BORD SOFT DECOR GRINIUM
FEUX INT. DIVERS LECTEUR DE CARTE
COMBINÉ (CARACTÉRISTIQUES) GRADUATION 220 KM/H 140 M/H FOND BLANC CERCL CHROM
HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE
INSONORISATION HABITACLE INSONO TABLIER 5KG+ARRET PTE+AUVENT+PEDAL
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE ASSISE AV PASSAGER REGLAGE PARALLELE
COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV A MEMOIRE CONDUCTEUR
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV MANUEL PASSAGER
RÉGLAGE ASSISE AVANT CONDUCTEUR MAINTIEN LAT FIXE CONDUCTEUR
RÉGLAGE ASSISE AVANT PASSAGER MAINTIEN LAT FIXE PASSAGER
ACCOUDOIR ASSISE AVANT MONTAGE SANS ACCOUDOIR AVANT
CONSOLE PLAFOND SANS CONSOLE PLAFOND
COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
LAMPES DE PROJECTEURS LAMPE HALOGENE
LÈVE-VITRE ARRIÈRE LEVE VITRE AR CDE ELECTRIQUE
LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE SEQUENTIELLE
LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE SEQUENTIELLE
AFFICHEUR AFFICHEUR (RADIO+MONTRE+ET OU T°,CD)
ACCESSOIRES INT. DIVERS AVEC FILET ANTI REMOUS
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
INDICATEUR D’HUILE RECEPTEUR TEMPORISE NIV + TEMP
MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE SANS APPUI-TETE AR
NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL AV DOUBLE
ECLAIRAGE BAS HABITACLE SANS ECLAIRAGE BAS HABITACLE
SAC GONFLABLE PASSAGER SAC GONFLABLE COTE PASSAGER
ORDINATEUR DE BORD AVEC ORDINATEUR DE BORD
PACK ÉQUIPEMENT SANS PACK EQUIPEMENT
RÉTROVISEUR EXTÉRIEUR RETRO EXT CHAUFFANT
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMMANDE INTERIEURE PORTE ASPECT CHROME
PLAFONNIER CDE A DISTANCE PORTES + PLAFONNIER AV
PROJECTEUR DIRECTIONNEL AVEC PROJECTEUR DIRECTIONNEL
PROTECTION POSTE AVANT SANS GRILLE DE SEPARATION
RANGEMENT (POSTE CONDUITE) VIDE POCHE INFERIEUR FERME A CLE + REFRIGERE
RÉCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS "RD4/MP3"
RÉFRIGÉRATION REFRIGERATION AUTOMATIQUE
RÉGULATEUR DE VITESSES REGULATEUR ET LIMITEUR VITESSE
REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
RANGEMENT (AUTRES) POCHES AUMONIERES
SURTAPIS (ASPECT) SURTAPIS MOQUETTE 1
SAC GONFLABLE CONDUCTEUR SAC GONFLABLE COTE CONDUCTEUR
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT BOMBE
RANGEMENT VOLUME CHARGEMENT AVEC FILET DANS COFFRE
TUNER-RADIO BI TUNER RADIO
PROTECTION INTÉRIEURE SANS PROTECTION INTERIEURE
INDICATEUR DE TEMPÉRATURE EXTÉRIEURE (GRADUATION) INDICATEUR TEMP EXT CELSIUS
DÉTECTION D’OBSTACLE SANS DETECTEUR OBSTACLE
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE SANS INDICATEUR PERTE PRESSION GONFLAGE
ADAPTATION GARNITURE POMMEAU LEVIER VITESSE ALU + SOUFFLET CUIR
SURTAPIS AVEC SURTAPIS
AMPLI-ÉQUALISEUR SANS AMPLI EQUALISEUR
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION +AUTOMATIQUE
VITRE CUSTODE (NATURE) VITRE CUSTODE DESCENDANTE
VITRE (TYPE) P-B FEUILL + LAT ET AR TREMPE
VOLANT VOLANT CUIR
VERROUILLAGE RANGEMENT VIDE-POCHES AVEC VERROUILLAGE
VENTILATEUR 1 VENTILATEUR 2 VITESSES 100W AERO
PACK AMBIANCE PACK AMBIANCE AV
SAC GONFLABLE GENOUX CONDUCTEUR SAC GONFLABLE GENOUX CONDUCTEUR
PRISE AUXILIAIRE PACK AUDIO 1 PRISE RCA AUDIO
Par contre il est sensé y avoir le régul, curieux
