Hi everyone,
I hope you can help me to a problem that has been annoying me for some time.
After some thought, I have chosen not to use 6x9s but to upgrade the existing REAR speakers in my 3 door 207.
I have been able to pull away some of the REAR panel to expose the speaker but not enough to get in and unscrew and replace. The panelling looks like it's clipped in but I do not want to force it.
Does anybody have any info on how to do this? Is it an easy job to do?
I don't want my music to be loud loud, just a little crisper and have more oomph!
Thanks for your help!
Problems replacing REAR speakers in 207
5 messages
Hi
do you unscrew the 3 screw in green in the picture ?
after pull the panel start at 1 to 9 in yellow in the picture don't worry (force it) about the noise but you will break some clippe's. After put your hand between the panel and the door to remove the switch of the window (pull it), remove the éléctrique cable and lift up the panel. that's all
lemanseb - Flood Addict
Hi i'm back
At first you have to remove the base of the seat. Then you remove the mask of the big screw of the seat belt then the screw. In the boot remove the white plastic (pull it) (Is still in place on the picture). Then you remove the big black pannel (pull it) start by the upright of the door, by coming down untill the bottom of door. Then you can pull the big black pannel by playing with the back of the seat.
I hope that you understand me.
5 messages
Retourner vers The English 207 board !
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 0 invités
